Civil 3D Forum
Ohio State Kit - OHDOT.lin file
2 REPLIES 2
595 Views, 2 Replies
I am currently setting up the Ohio State Kit for C3D 2015 for my firm to use on future projects.. I followed the download instructions and everything worked flawlessly.. I have noticed in my test files that the linetypes look weird from a converted dgn to dwg file that uses ODOT's microstation standards.. Long story short I did a windows explorer search for the OHDOT.lin file that is supposed to be included with the install files and it is not on my computer.. Has anyone experienced this? Has Autodesk provided the .lin file to anyone?
Thanks in advance!
2 REPLIES 2
Civil3DReminders_com
Looks like it got left out of the install files for 2015 (or is installed in the 2014 folder). I found mine here, but I've downloaded and installed both versions so I'm not sure how it got there. C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Support\Linetypes
Funny it's also in the wrong folder regardless. It probably should be located in this folder C:\Users\Christopher\AppData\Roaming\Autodesk\C3D 2015\enu\Support
I've attached it to this post.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
in reply to: Civil3DReminders_com
Thank you for the help and the attachment!! I didn't think it was on my computer..
Rail Community
