I regularly use viewports to show monuments that may have 100's of between them. I skipped over 2023 but installed for testing and get the same results. In the image below is 2 viewports. The upper view is the original viewport that I created; the bottom is a copy of the original viewport to just show the area I want to appear. When I regen the copied viewport the Crowsfeet disappear. Nothing is frozen, no layers have been changed. I've tested this in a new drawings from the original dwt and the NCS dwt, and in both instances, I get the same result. The copied viewport loses the crowsfeet.
This happens in both 2023 & 2024 but when I open the same file in 2022 the crowsfeet appear. I considered possible is this something to do with TOGGLELABELVISIBILITY, but I have turned that off.
Has anyone else seen this? Could I be missing something? I've attached a file for reference.
For now, it's back to 22 unless someone else has a solution. I'm at my wit's end on this one.
Rick Jackson
Survey CAD Technician VI
