Civil 3D Forum
Vertical grid not shown on profile view
7 REPLIES 7
Message 1 of 8
Kalhab
3409 Views, 7 Replies
Hi everyone,
Sometimes when I create a profile view using C3D 2016 &2017, I notice that the vertical grid lines are missing from my profile view. I've checked all my settings even, I imported settings from other DWG that display the vertical grid but the problem still persists. the only option that now I use is to change the profile view style to other one and modify it to my style. Anyone else know how ro fix this with out changing the profile view style?
7 REPLIES 7
Message 2 of 8
Hidden_Brain
in reply to: Kalhab
check the profile view style for the layer name the vertical grid lines are on. then check that layer in the layer manager if it is turned off or frozen.
Message 3 of 8
Kalhab
in reply to: Hidden_Brain
I checked the layers are on and not frozen in  profile view setting and layer manager. the problem is still there.
Message 4 of 8
wfberry
in reply to: Kalhab
I believe you could get this resolved rather quickly if you would post a small dwg of your problem.
Bill
Also, I cannot tell for sure if you are showing a picture of Model Space but in your Pic 2 NOT SHOWING is VP Freeze (Only if you are in a ViewPort)
Message 5 of 8
Kalhab
in reply to: wfberry
here is the sample C3D 217 dwg.
Message 6 of 8
wfberry
in reply to: Kalhab
With such a long alignment, you need to change the horizontal frequency and all is well. Change the Major and Minor Tick Interval to a wider spacing.
Bill
Message 7 of 8
Kalhab
in reply to: Kalhab
when I change the major tick interval to 100 m and minor tick interval to 20 m, it worked.
thanks
Message 8 of 8
Kevin.Hotchkiss
in reply to: Kalhab
I was running into this issue also after changing profile from View from Right to View from Left. I found that it was because my left/right vertical axis and top/bottom horizontal axis had different major tick intervals. This caused the grid to add lines splitting the difference between the major intervals.
Rail Community
