As one of those random things that pops up from time to time, I need to consider the ability to maneuver trucks at a number of potential earthwork sites. I downloaded the Vehicle Tracking extension (trial) and have it working with my IDSP 2018 installation.
Specifically I want to look at a 'typical' truck and dog trailer combo - see pic attached. I thought this would be pretty common vehicle but couldn't find a good match in the vehicle library. I did find this:
https://knowledge.autodesk.com/support/vehicle-tracking/troubleshooting/caas/sfdcarticles/sfdcarticl... indicates that the question has probably been asked before.
I'm sure it's not as confusing as it seems at first glace, but as I'm not really looking to invest a heap of time in this I was hoping that either someone has done exactly what I'm after and would be willing to post the vehicle or maybe a quick screencast to modify a vehicle?
Mick
Solved by Jowennl. Go to Solution.
Solved by Neilw_05. Go to Solution.
Personally I've never heard of a "dog trailer" designed exclusively for dogs. Thus I doubt you'll find a pre-configured "dog" trailer. I could be wrong. I think you'll need to create a custom trailer. Pick one of the existing trailers and add it to your vehicle, then tweak the parameters after.
Thanks Neil, Maybe it's just an Aussie term. I think the pic shows what I'm talking about: Rigid body dump truck with a trailer on a long drawbar (the trailer is jack-knifed to allow the rigid truck to dump its load). I'm not sure how to add a trailer from one vehicle, onto another. I understand the idea is to edit a copy of the vehicle as part of the drawing pool, but I'm having trouble mixing and matching.
Cheers
Mick
That is so funny! The image you posted didn't show for me so I couldn't see what you were talking about. I visualized a dog kennel on wheels!
Anyway I'm new to AVT but I've learned how to link 2 vehicles using drag and drop. Basically you place the lead vehicle in your pool and then drag the towed vehicle onto it. The software links the 2 for you. I added a small SUV to a Big Rig RV for example. In my case I had to manually toggle on one of the settings to make the RV a tow vehicle. After that they linked. I also had to tweak the length of the tow bar afterwards.
Hah! Or maybe one of those little pet wash trailers. I can imagine dragging that around the construction site seeing if anyone had a lapdog that needed grooming.
Seriously, thanks for the tip, I'll experiment more.
Cheers
Mick
Hi Mick,
Please see attached _Aussie-Additional-Vehicle.Zip. You need to unzip and copy the _Aussie-Additional-Vehicle.ATL to C:\Users\<<YourUser>>\Documents\My Vehicle Tracking Data\Library
Please use this as a guide only. Check and amend them to suit your T&D specification like radius as I believe 12.5m radius is the common one. For more info about AVT library please visit this <Link>
For how to load them and edit please see attached animated gif.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
Interesting term. Where I work (Continental US, pacific northwest) the trailer is called a pup-trailer, so the whole thing (truck + trailer) is a dump truck with pup trailer, or just dump w/ pup.
The drawbar is adjustable, for reasons I am not 100% sure of (I called a couple manufacturers to get exact measurements to program my own custom vehicle, and they replied that it has to do with roadway & bridge load ratings - for heavier loads the driver extends the drawbar to spread the axle loading out more). So if you build a custom vehicle for vehicle tracking, consider making two: One w/ drawbar fully retracted, one w/ drawbar fully extended.
Or just assume worst case, and model it w/ drawbar fully extended.
@jeff_rivers maybe our dogs are bigger than your pups? Good point regarding the drawbar length. Thanks
@Jowennl thanks heaps for putting that together - I was able to load and use that. I'm slowly getting the hang of the editing side now. I think it's now it's mainly a matter of getting the right specs.
BTW - interesting trying to reverse these in ATV. Not sure if there's other settings that need to be adjusted here.
Cheers
Mick
and a trailer with four axles is a 'quad dog'
You've gone to some effort here, thank you mate, really appreciate it
Regards
Charlie
