using .NET code to change base/comparison surface from volume surface
r_griffith
r_griffith
There are already a lot of topics about changing the base or comparison surface from a volume surface, using the workaround to create 2 dummy surfaces for the volumesurf, and paste the source data in those dummies.
But then i encountered this old post from @Jeff_M that wrote a .NET code to replace breakline sets:
https://forums.autodesk.com/t5/civil-3d-customization-forum/surface-definition-operation-type-automa...
That got me thinking. Could that .NET file be altered so you could replace the base, or comparison surface from a volume surf that's already there?
We use a lot of volume surfaces from datashortcuts and it's tedious to always create 2 dummy just in case you'd want to change 1 surface later on. And since it's datashortcuts you can't paste your new data in that base. So i hope that some .NET code could fix this 🙂
neilyj666
 I doubt it is possible purely on the basis that if it were it would have been done by now...!!!
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
