Show only
Search instead for
Using Autocad 360 Display Station Offset from Autocad File
Is there any way to display station/offset from GPS location in Autocad 360 from an Autocad file? Is the only way if you added the information to the drawings and compared to your current location?
If you have a NMEA GPS enabled Windows laptop or tablet, you can take Civil3D and your actual drawing into the field. With this low cost add-on you can get real time station/offset feedback (and a lot more).
