Civil 3D Forum
Civil 3D 2016 UKIE toolbox issues
3 REPLIES 3
neilyj666
401 Views, 3 Replies
Anyone using  the Civil 3D 2016 UKIE version??
I have tried a couple of tools in the toolbox but the dialogs open weirdly - I've tried on two different computers and as a differerent user but the result is the same each time
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
I get the same result when running the corridor gap fill and export for construction tools from the UKIE tools in Civil 3d 2016.
I have tried running it from Civil 3d started using the ANZ and Metric profiles and get the same result.
Looks like a bad implementation of the tool on palettes.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Andrew
Thanks for the confirmation that it isn't just me.....although in the Benelux kit, it appears to be working correctly
http://autodesk.typepad.com/bimtoolbox/2015/07/prepare-a-civil-3d-design-for-automated-machine-guida...
neilyj666
in reply to: neilyj666
The solution appears to be to resize the window so all the dialog box is visible, shut it and then reopen (and it also seems to reopen correctly after shutting down and restarting C3D but not sure if it will on a PC restart)
Rail Community
