Use horizontal distance for circle radius
tkirbytrinity
tkirbytrinity
When drawing a circle using two points on objects with different elevations, I would like the radius to be the horizontal distance between the points.  Currently my solution is to draw a polyline between the points and then draw the circle snapping to the ends of this polyline.  Is there a more direct way to get this result?
Thanks!
P.S. This question was asked in 2005 and never answered: https://forums.autodesk.com/t5/civil-3d-forum/circle-through-a-point/m-p/1440764
cwr-pae
Osnapz = 1 before you draw the circle. But for me the CI, 2p command (circle between 2 points) always produces a circle with the horizontal distance but the center z is the 1st point selected.
tkirbytrinity
Perfect.  I was hoping there was a system variable solution.  Circle between two points isn't great for me since I typically want to define the radius.  Thanks!
