Update Notifications for Civil 3D and Raster Design
ricky.dalessandro
Message 1 of 11
ricky.dalessandro
In the start tab Notifications say I have 2 product updates but when I go to Update there are none listed when I go to the App. Running Civil 3D 2019 with Raster
@ricky.dalessandro
john.vellek has edited your subject line for clarity: Notifications
Replies (10)
Message 2 of 11
cadffm
Login to your account a check available updates for
Autocad, Civil3D and Raster(?),
Check for updates there.
https://accounts.autodesk.com/Authentication/LogOn?ReturnUrl=%2Fauthorize%3Frealm%3Dmanage.autodesk....
Sebastian
Message 3 of 11
ricky.dalessandro
Logged in and no updates available
Message 4 of 11
pendean
Community Legend
Community Legend
Updates are always posted here for the software you are allowed to use if you have been given access to do so by your license manager (not one here can change that for you) and your log-in is the correct one for the license number you are using https://manage.autodesk.com/cep/#products-services/updates
BTW, the start page may be just plain wrong too.
Message 5 of 11
john.vellek
Hi @ricky.dalessandro,
Can you give me the exact versions of Civil 3D and Raster Design?  It will help to know if they are fully up-to-date and if the notification is wrong.
Do you see any updates available in your app?
John Vellek
Message 6 of 11
ricky.dalessandro
Using Civil 3D 2019 and Raster 2019, no updates showing up in the App but in the Notification area in the Start Tab it says in the Yellow box "You have 2 product updates." And a number one above the Yellow box to the right of Notifications.
Message 7 of 11
john.vellek
Can you type ABOUT at the Civil 3D command line and share the version information? Did you last install updates manually or through the desktop app?
John Vellek
Message 8 of 11
ricky.dalessandro
 Product Version: 13.0.613.0 for Civil 3D 2019
Built on:
P.162.0.0 AutoCAD 2019.1.2
22.0.022.16 Autodesk AutoCAD Map 3D 2019.0.1 Update
8.1.48.0 AutoCAD Architecture 2019
Message 9 of 11
john.vellek
My Civil 3D  shows
13.0.863.0 Civil 3D 2019.1 Update
AutoCAD Architecture is 8.1.48.0 AutoCAD Architecture 2019.0.1 so there is likely an update available.
So it appears that there are some updates available. If you start plain AutoCAD does it show that it is fully up-to-date?
John Vellek
Message 10 of 11
ricky.dalessandro
It shows the same updates for Straight AutoCAD
Message 11 of 11
wfberry
You may have downloaded an update but never installed it.
Bill
