Hi, I have formatted my pc and installed fresh windows 10. Then installed Civil 3D 2023. While I was installing updates of Civil 3D 2023, two of the update could not installed - Coordinates and Transformation Tool 2023 for Civil 3D and PPK Survey Extension 2023 for Civil 3D. Other updates were installed perfectly such as SHP tool, project explorer...
I have found below article for this problem, but couldn't solve it.
I believe there is a bug in the xml files of the setup file such as PPK_Survey_2023 setup.xml and ucp.xml as setup cannot identify the location of Civil 3D exe file.
This problem occurs in all my team member's PC.
Anyone has the same problem? and found out a solution?
Solved by abd_eng_001. Go to Solution.
Finally I found a solution. Like I suspected, problem was in setup.xml config file.
Solution goes like this:
1. Once Transformation_2023.exe or PPK_Survey_2023.exe is downloaded, right click the exe file and unzip them (7zip can be used)
2. In the unzip file there is a file "setup.xml"
3. Open the xml in Notepad++ and go to the line 28, where the line is this =
<Condition messageId="prerequisite1" state="NOT_APPLICABLE" type="PREREQUISITE"><![CDATA[NOT(%ADSK_WIN_INSTALLED_MSI% CONTAINS {28B89EEF-5100-0000-0102-CF3F3A09B77D})]]></Condition>
4. The bolded number is 5100, this should be changed to 6100. Then save the file.
5. Start the setup.exe file to install it.
Hope it helps.
You are the man, worked flawlessly. I did run into a similar issue with C3D 2022 trying to install geotechnical toolkit. I don't speak code. Thank you so much, your efforts are much appreciated.
Why can't Autodesk fix this? It's THEIR product. They should pull the update, FIX IT, and re-post. Thank you for this solution. Works great!
@abd_eng_001 Make an AKN about / for this...
I saw the ticket and escalated it up ...
@mdavis22569 you know as well as I do, that don't mean anything. 🙈🙉🙊
I know .. I could make the AKN article for him ... but don't want the credit.
I could put a link to his profile in it ...
Would that help / work?
yes, you are able to install via the desktop app or direct download of exe file as Autodesk fix the problem. As can be seen in the screenshot, they released new update.
they may have fixed the updates
looks like they re released both of these updates yesterday
DarrenP
Sir,
please do you have a link to the PPK and Transformation tool .exe files, i cant find them in my civil 3d 2022. I understand i need to download and install updates. please help with the link, you can send the link or exe file to nsikakobonge1@outlook.com; usfieldmarshal@gmail.com
thanks for your help
Hi everyone!
Sorry for bring this topic up but I need help and try understand why I can't find this precisous tool on my civil 3D 2023. I can't find direct download links on the site, either on the Autodesk Access app.
Sometimes I try understand Autodesk's team, because sometimes the program and those situations is unreal for the price of this softwares.
Thank you for your atention and help.
Kind regards!
It is in the website, https://manage.autodesk.com/. if you follow the Civil3D and choose the version 2023, and then "Available downloads - Extensions" you will be able to download and install. Here is the screenshot.
