- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I have formatted my pc and installed fresh windows 10. Then installed Civil 3D 2023. While I was installing updates of Civil 3D 2023, two of the update could not installed - Coordinates and Transformation Tool 2023 for Civil 3D and PPK Survey Extension 2023 for Civil 3D. Other updates were installed perfectly such as SHP tool, project explorer...
I have found below article for this problem, but couldn't solve it.
I believe there is a bug in the xml files of the setup file such as PPK_Survey_2023 setup.xml and ucp.xml as setup cannot identify the location of Civil 3D exe file.
This problem occurs in all my team member's PC.
Anyone has the same problem? and found out a solution?
