Uninstall update 6 silent
klaus_hart
Message 1 of 10
klaus_hart
I need to uninstall C3D 2020 update 6 silently with sccm, how can i accomplish this?
I tried with:
msiexec.exe /x {6979BD25-3600-479A-1001-72684B59A545} /qn /quiet /passive /qb ... but nothing uninstalls it.
the uninstall script from autodesk, the official one - I dont understand it enoguh to adjust it for this update 6.
Please help
Replies (9)
Message 2 of 10
wfberry
Where did update 6 come from.
Bill
Message 3 of 10
rl_jackson
If you want to uninstall a update try doing a RESET should be located in the up right area. I think it's in the About section. This will reset C3D to default OOTB install.
Rick Jackson
Survey CAD Technician VI
Message 4 of 10
klaus_hart
We installed it trough sccm,  but it turns out, at least on our case, that it slows down the start of C3D. Instead of couple seconds it takes 2min! Don't want to get into this right now just silently uninstall the update and we are happy.
Message 5 of 10
klaus_hart
I tried this today like in the official documenation for C3D 2020 update 6 and it did not work:
msiexec.exe /x {6979BD25-3600-479A-1001-72684B59A545} /quiet
BR
Message 6 of 10
Pointdump
Hi Klaus,
"...uninstall C3D 2020 update 6 silently with sccm..."
I have no idea what SCCM is, or why it is so noisy for you, but any update can be uninstalled in Windows the same way you'd uninstall any program.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 7 of 10
klaus_hart
there is this thing called Google, so you can type in "SCCM". I thought that Autodesk Expert Elite should know this. It would be better if you just skipped the thread and moved on instead of putting together a few words on your keyboard. I have to uninstall this for lot of users, 60+ and doing it the way you gracefully suggest it is not time efficient.
Skip and forget it, thanks.
Message 8 of 10
andrewpuller3811
A search through the registry shows that {6979BD25-3600-479A-1001-72684B59A545} comes back as Autodesk Civil 3D 2020 Object Enabler under the key Autodesk Civil 3D 2020.6 Object Enabler 64 Bit.
After a lot more searching, I found the a silent uninstall string for the 2020.6 update under the key Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{99d1447d-3000-0000-0102-101d0a553893}
The silent uninstall string is "C:\ProgramData\Package Cache\{99d1447d-3000-0000-0102-101d0a553893}\C3D_2020_6_Update.exe" /uninstall /quiet
Give that a try and see if it works.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Message 9 of 10
rl_jackson
I just installed this update this morning, not having any load issues at all.
Rick Jackson
Message 10 of 10
klaus_hart
thanks this worked.
The registry path: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall is the one to find the App ID.
Also something that works is:
C3D_2020_6_Update.exe /uninstall /silent
Here the issue is, that you have have the 400MB "heavy" .exe file on the client.
Much appreciated!
