File open issue
File open issue
Joe-Bouza
Mentor Mentor
File open issue
Joe-Bouza
My machine will not open the same files my coworker can.
my wheels spins for an hour and maybe will open. My coworker opens the same file in 10 seconds (they are small files)
we have the exact same OOTB settings.
I am see it the same with DC. I am on VPN with typically no issue. Graphical acc on/ off done
What else can I look at
Joe Bouza
tcorey
Hello @Joe-Bouza
You have emptied your local temp folder?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Joe-Bouza
Hi Tim
I had not but no change after wards
Joe Bouza
Joe-Bouza
Here is the wierdness:
in a different folder I recreated the files and xrefs from scratch pulling in layout tab info and restoring views. I have the exact same files and the ones in the new folder open without incidence
Joe Bouza
Joe-Bouza
Do tyou know id sid files cause a problem? these files have/ had sid attached
Joe Bouza
