Civil 3D Forum
Two Finished Ground Lines in Section View
2 REPLIES 2
325 Views, 2 Replies
Hello
There are some section views that have two finished ground lines, one coming out of the top corner of the pavement and the other from the bottom. I can't seem to figure out the problem. I am using DaylightMaxXWidth for daylighting.
I have attached some pictures.
Thank you in advance!
2 REPLIES 2
tcorey
Can you post the drawing, or post a drawing that has your assembly in it.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jeew-m
Having the dwg will be better.
But before that please look at these.
Are these happening at the stations where corridor region changes.
If so you can have a small gap between the regions.
Also make sure you have set a frequency station of corridor at the section view station.
Finally make sure you have added correct top/bottom link for overhang correction of corridor surface.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Rail Community
