TO ARRAY OBJECTS ON ONE AXIS
mikes10259P8UW
mikes10259P8UW
I'm trying to align the space between selected boxes shown in my attachment. I want them all on the same y-coordinate.
I tried changing the 'Between' and ' Total' options in the Row panel. It does change the y-coordinates of the boxes so I assumed changing it to 0 would move them all flat along the larger box. Any suggestions? Thanks.
Mike
trevorG6RBX
I think that the easiest way to do this would be to use a path array instead of a rectangular array. If you make a path with the same Y coordinate it should follow the path and solve your problem
mikes10259P8UW
Thanks TrevorG6RBX. I will check this out soon.
