i have a drawing that is in 2016. i have also loaded it in 2018, same results. i created a structure with rectangle shape, (its a junction structure) 8x14. i put it longways in the pipe run. then i twist it in the profile. it should change to 8' but it doesnt. if i swap the part, that changes. i have checked object view and i have it correct. its almost like the profile is set to static. also, i dont if this helps. if i change the structure style under profile to solid it behaves correctly. i would use that but its showing the pipes going into the structure, not masking it. i have attached 3 images. the first 2 are with profile set to boundary the last one, i changed it to solid. it looks right and then when i rotate it, its still good. i am at a loss and of course i have to get this job out in a day or two.
thanks
jay
