network structure not updating in profile-help
jmola
jmola
i have a drawing that is in 2016. i have also loaded it in 2018, same results.   i created a structure with rectangle shape, (its a junction structure) 8x14.  i put it longways in the pipe run.  then i twist it in the profile.  it should change to 8' but it doesnt.  if i swap the part, that changes.    i have checked object view and i have it correct.  its almost like the profile is set to static.   also, i dont if this helps.  if i change the structure style under profile to solid it behaves correctly.  i would use that but its showing the pipes going into the structure, not masking it.   i have attached 3 images.   the first 2 are with profile set to boundary the last one, i changed it to solid.  it looks right and then when i rotate it, its still good.  i am at a loss and of course i have to get this job out in a day or two.
thanks
jay
Hidden_Brain
this has been a long standing issue AFAIK with the only workaround to display as solid.
Hidden_Brain
if i remember correctly, in profile view the structure is drawn based on its width and not length. perhaps you can display the structure using a custom block in plan to show correctly, and swap the length for width in part builder. that way, it will show longer (wider) in profile view.
worth a shot i guess.
jmola
after fooling around with it.  it seems to work.
