We recently updated to C3D 2022. When I opened one of my drawings I noticed most of my spot elevations had the orange "i" in an orange circle. I understand this is the result of the label style being manually changed. I have also seen where this can be turned off by deselecting the "Drafting" option under the AEC Editor tab of the options menu. My question is, does turning this off potentially affect anything else?
Solved by pghcivil3d. Go to Solution.
Hello, turning this function off should not affect anything else. This is just more of an informative feature that would let the user know that there was an override.
Rob Sinclair
Thank you sir.
