Civil 3D Forum
TIN Lines Crossing Breaklines
5 REPLIES 5
alexRR6ZB
290 Views, 5 Replies
I've got tin lines crossing a breakline and i can't figure out why. any ideas?
5 REPLIES 5
ecfernandez
in reply to: alexRR6ZB
Hi @alexRR6ZB, I hope you're doing fine.  Try activating the supplementing factors when adding the breakline
Use a small distance and see if that helps
Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
_Hathaway
It doesn't look like its an actual breakline.  Maybe recreate it, select it then add as breakline to the surface.
alexRR6ZB
thanks for the response guys. it is indeed a breakline and I did use supplementing factors. I ended up removing some manually added tin line and reapplying it as a breakline to the surface. It works fine now. i don't have an explanation for this but I'll take it.
Joe-Bouza
Manually added tin lines and point will do exactly what you experienced; confusion?
use real data you can easily track.
less is more. Well realty more is more but you get the idea.
Joe Bouza
ecfernandez
Hi @alexRR6ZB, chances are that some previous editions made in that same place of the surface affected the correct creation of the new surface's geometry after adding the breakline.
It is good that finally it is solved. Have a good day
Best regards!
Camilo Fernández
LinkedIn
Rail Community
