Turn off Dialog Boxes for Commands
Message 1 of 12
Is it possible to disable dialog boxes / pop-ups for commands?  More specifically, can you disable the dialog box from popping when using the edit surface swap edge command?  It is pretty annoying when cleaning up a huge surface and you accidently click on a contour line instead of just ignoring it a box pops up and says "no edge at picked location".  Autodesk, thanks for pointing out my mistake everytime, you remind me of my mother-in-law...
Anybody know if this is possible?
Mark
Replies (11)
Message 2 of 12
Pointdump
Mark,
This one?
Dunno. The only thing I can suggest is to turn off your border and everything but triangles.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 12
Joe-Bouza
Have you tried FILEDIA=0?
Set Panama to auto hide
Optional- turn auto build off: I know that defeats your purpose, but will eliminate any pop ups until rebuild occurs
Joe Bouza
Message 4 of 12
Pointdump
Joe,
"Set Panama to auto hide"
But how will ships find the canal to be able to cross over?
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 12
Joe-Bouza
Its confusing enought that you have tp head west to get to the Atlantic and East to the pacific
Joe Bouza
Message 6 of 12
jmayo-EE
If this is the issue Dave then the OP should just be able to use a crossing window selection instead of a single click selection. This will find the triangles under borders and contours.
John Mayo
Message 7 of 12
AlmasSuljevic
Autodesk Support
Autodesk Support
Hi Mark,
I don't think it's possible to ignore this dialog, but there may be a good way to workaround it. If you select your surface, right-click on it and select "Isolate Selected Objects" you may be able to remove all that noise and just work on your surface triangles. Once done, just repeat the procedure and "End Isolation". Not quite what you are looking for an answer but since it acts as designed this may be useful.
Let me know if it works.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 8 of 12
Thanks for all of the suggestions.  Pointdump, yes that is the one.
I thought I was on to something with the cmddia variable but that doesn't work either.  Sounds like it can be reduced but not made to go away.
I wish it was more like other commands where if you select the wrong object it just says ".. filtered out.." in the command line.
Thanks again.
Message 9 of 12
Jeff_M
@Anonymous, with a wee bit of .NET programming this can be done. In fact, I have a solution which doesn't force you to actually pick the TIN line to swap, just pick something on the surface and the nearest TIN line will be attempted to swap. If it can't be swapped it is reported at the command line and let's you continue on. If you wish I will share the code, but not a working DLL (it's part of a larger tool set, not a standalone project.
Message 10 of 12
Jeff,
Sure, I would appreciate that. I do a little .net on the side so I should
be able to get it working.
Message 11 of 12
Jeff_M
OK, here's the c# class:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil;
using Autodesk.Civil.DatabaseServices;
using Autodesk.Civil.DatabaseServices.Styles;
using System;
namespace Civil3D_Misc_Commands.SurfaceTools
    public class SwapEdge
        [CommandMethod("SwapEdgeToo")]
        public void swapedgetoo()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityOptions eOpts = new PromptEntityOptions("Select Surface: ");
            eOpts.SetRejectMessage("...not a Tin Surface, try again.");
            eOpts.AddAllowedClass(typeof(TinSurface), true);
            PromptEntityResult eRes = ed.GetEntity(eOpts);
            if (eRes.Status != PromptStatus.OK)
                return;
            eOpts.Message = "\n..Select edge to swap: ";
            var surfId = eRes.ObjectId;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var s = (TinSurface)surfId.GetObject(OpenMode.ForRead);
                var style = (SurfaceStyle)s.StyleId.GetObject(OpenMode.ForRead);
                var ds = style.GetDisplayStylePlan(SurfaceDisplayStyleType.Triangles);
                if (ds.Visible == false)
                    ed.WriteMessage("\n Surface is not displaying Triangles, exiting...");
                    return;
            while (eRes.Status == PromptStatus.OK)
                if (eRes.ObjectId != surfId)
                    ed.WriteMessage("...not the same Surface!");
                    continue;
                    var surf = (TinSurface)eRes.ObjectId.GetObject(OpenMode.ForWrite);
                    var edge = surf.FindEdgeAtXY(eRes.PickedPoint.X, eRes.PickedPoint.Y);
                    try
                        var surfOp = surf.SwapEdge(edge);
                    catch (SurfaceException e)
                        if (e.Message == "CantSwap")
                            ed.WriteMessage("\n Can't swap that edge!");
                    catch(SystemException e)
                        ed.WriteMessage("...Something unexpected happened, this is the message:\n {0}", e.Message);
                    tr.Commit();
Message 12 of 12
Thanks Jeff.
Mark
