Transparent Command Graphics Problem
Beka_Tchigladze
Advisor Advisor
Beka_Tchigladze
I have Civil 3D 2022 with the latest updates,
I cannot see graphics when I use Transparent Commands, either with polylines, alignments or profiles, it has same problem with everything before I turn off graphicsconfig after it is better then before, but not as desired. in previous versions of Civil it worked excellent, but now it doesn't work properly. I have latest Updates for my Graphics card RTX 3060 drivers. I have tried with GTX 1050ti also with old driver, but it had the  same problem.
Have you ever had the same issue with latest Civil? how can I solve a problem?  
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
rl_jackson
You'll probably have to run with Hardware Acceleration off, for it to work properly, your Graphics Card is not an approved card for C3D. My older Quadro Card has no issues.
Rick Jackson
Survey CAD Technician VI
Beka_Tchigladze
Hm that is not sounds good,
will it change anything if I will install studio driver?
Beka Tchigladze
Alfred.NESWADBA
try to let hw-acceleration active, however, set variable GFXDX12 to 0 (and restart AutoCAD) so AutoCAD just uses DirectX11.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Beka_Tchigladze
@Alfred.NESWADBA
Doesn't work 😔
Beka Tchigladze
Alfred.NESWADBA
sorry to read that it did not help, then please verify the installed updates as shown in my screenshot.
If all modules are updated on your system too then you need to find a different driver for your graphic card.
For me polyline and transparent 'AD works well (as one sample tested).
- alfred -
Alfred NESWADBA
Beka_Tchigladze
@Alfred.NESWADBA
Dear Alfred,
Thank you to share your experience you are really important person 👌
both of them were out of dated, I donot know which of them was a problem but now it works perfectly Thank you again.
Beka Tchigladze
