- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have Civil 3D 2022 with the latest updates,
I cannot see graphics when I use Transparent Commands, either with polylines, alignments or profiles, it has same problem with everything before I turn off graphicsconfig after it is better then before, but not as desired. in previous versions of Civil it worked excellent, but now it doesn't work properly. I have latest Updates for my Graphics card RTX 3060 drivers. I have tried with GTX 1050ti also with old driver, but it had the same problem.
Have you ever had the same issue with latest Civil? how can I solve a problem?
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
