‘Transition between two different surface targets is not supported yet’
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In a nutshell, this is the problem:
Here's a drawing file.
- From the feature lines created, I have used ‘Grade to Surface’ to have slopes of different ratios.
- After grading, I used the Grade Transition to connect these slopes of different ratios.
- However, the transition was not able to be created at one end of the platforms (Refer to Image 1) which I will get an error ‘Transition between two different surface targets is not supported’
- In this drawing, there’s only one surface that can be targeted, so how come the grading created by the program is from two different surface targets?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
Ngu Soon Hui
