How to create multi layer slope ( with different slope ratio)?
soonhui
Advisor Advisor
soonhui
Here's something I want to create:
Take a look at the red part, they are slopes, and they are of different plan length and slope ratio, and they are repeating ( eg: first layer of slope has plan length =2m, ratio 1:2, the second layer of slope has plan length 2.5m, ratio 1:3, and they repeat until they hit the ground).
So how can I achieve it easily without manually creating every single layer of the slopes?
I can( the drawing file) use Feature Lines with the following steps:
  1. Create polylines outlining the platform shapes
  2. Convert the polylines to Feature Lines together with their elevations at each corner
  3. Create feature lines to outline the slopes and berm contours. As for conjoined platforms with vertical drops in between, I created a small gap in between and used feature lines to enclose the gap which will also connect the edges of different elevations.
  4. Select all the feature lines individually > Add as breaklines to Surface
But as you can see, it is a very manual process because I still have to specify every single layer of the slopes down to the ground level, even though the slope layers form a pattern and are largely self repeating.
Is there anything in the Grading option that allows me to do that? I don't think so because Grading only allows one to specify one slope ratio instead of many.
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
AuditInPaperSpace
Hi!
I'm actually not quite sure what you are trying to grade/model with the surface, but I think I understand what you are technically trying to accomplish. You actually can use grading features for this!
The key capability is that you can create grading features based off of other grading features. You can layer them all together like you described.
Once you have your initial grading feature created,
you can create another one:
You can just keep creating grading features based off each other:
And yes, these are all dynamically linked, so if you update the elevations of the outermost feature line, all the inner grading features update.
Additionally, you can raise/lower a bunch of feature lines at the same time, by a specific elevation difference, which may also accomplish what you want. You might not even need grading features:
lim.wendy
Hi
Thank you for submitting your question in our discussion forums. I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community! Have you had a chance to look over the suggestions provided by Seth?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
