Civil 3D Forum
Toolspace Prospector and Settings buttons have red outline and wont open
6 REPLIES 6
1647 Views, 6 Replies
This could be a very simple problem. I toggled off all of the buttons in the Palettes tab (prospector, settings, survey, toolbox). The Toolspace button greyed out. However, when i toggle the buttons back on and open the toolspace, i can only see the survey and toolbox side-tabs. The prospector and settings buttons in the palettes tab have a red outline.
Labels (1)
6 REPLIES 6
lim.wendy
Hi @Anonymous
Welcome to the forum and thanks for posting.
If you toggle between different workspace in Civil 3D, i.e going from Civil 3D to Planning & analysis
Otherwise, you might want to try to reset C3D.cuix
Let us know how it goes.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
in reply to: lim.wendy
Thank you for your reply. Switching the workspace didn't work. I tried to reset the C3D.CUIX but it says it has been "moved, renamed, or deleted", and to type CUILOAD at the command prompt. I could do this but im not sure where i would load it from.
I am using the student version.
Thanks!
Miguel_Sepulveda
Cierra todos los archivos y desde la ficha "Start", crea uno nuevo
Saludos
Miguel_Sepulveda
Close all the files and from the "Start" tab use the "new" button to create a new file.
lim.wendy
@Anonymous,
In addition to @Miguel_Sepulveda suggestion, typically, the error message indicates that the CUIx file is damaged.
Check out this knowledge article to locate the location of the CUIx file:
Error: "Unable to open customization file" and ribbon not loading in AutoCAD
Wendy Lim
Rails Summit
Thanks! I followed the steps and replaced the .cuix files. I seem to still have the issue. However, if I just close and re-open the drawing the prospector and setting tabs reload. I will just not turn them off in the first place.
Thank you for your helpful replies,
Rail Community
