Tool Palettes Question
neilyj666
Mentor Mentor
Message 1 of 12
neilyj666
When I right click on the Tool Palettes the following is shown which is as expected but there are Palettes shown e.g. Civil Imperial Subassemblies, Lights, Cameras that I am unlikely to ever need and there are Palettes that I use frequently that are buried behind a few more clicks
Is there a way to organise what is shown here so my most used palettes are visible all the time?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (11)
Message 2 of 12
rl_jackson
If you select the gear to the upper left bottom, there is a Customize Pallets. This is very similar to make edits with the CUI interface.
Rick Jackson
Survey CAD Technician VI
Message 3 of 12
Joe-Bouza
Good question
Joe Bouza
Message 4 of 12
Joe-Bouza
Good answer.
the gear is on the fly out list?
Im over looking it
Joe Bouza
Message 5 of 12
neilyj666
Thanks - hiding in plain sight...!!!
Palettes rearranged into a more user friendly order; only taken from the 2011 release for me to do this...🤣
Message 6 of 12
Joe-Bouza
@neilyj666  & @rl_jackson
how do you change the order and what is listed?
Joe Bouza
Message 7 of 12
neilyj666
@Joe-Bouza click the top gear (or right click in the grey bar where the Civil Imperial Assemblies is showing) to get to the Customize Palettes menu, Select it and then drag the Palette Groups (right hand side of the dialog) to the preferred order. Right click in the palette Group to delete/rename and right click a palette (in the Palette Group side to remove it)
Create a new palette group (or amend an existing one) and then drag palettes from the left to the right as required - very similar to CUI modification
Message 8 of 12
brian.strandberg
I'm going to present another option.  Rather than customizing palette groups, we put this statement in our CUI.  When someone needs certain functionality, they can use this function in our CUI.
This will set the path to a folder with a particular set of tools.  I really like how this is repeatable, when someone uses this function, everyone will get the same setup.
(progn (command "*_TOOLPALETTEPATH" "J:/CAD/CAD_ADMIN/Palettes/Civil")(command "toolpalettes"))
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 9 of 12
neilyj666
Can you provide some more info about this approach - look useful
Message 10 of 12
Joe-Bouza
Easy enough. Thanks
Joe Bouza
Message 11 of 12
rl_jackson
@brian.strandberg
Does that change the path in the OPtions for Tool Palettes File location, or does it append it.
Rick Jackson
Message 12 of 12
brian.strandberg
The way I have it setup there changes the path which is probably easier for us.  You can see the example from the CUI below, I have had to redact several company names we work with.
Each of these include 5-10 palettes.  The disadvantage it is doesn't save any palette customization, but with around 5 palettes that is typically not an issue.  Where it does become an issue is Civil 3d saves its metric and imperial palettes in the same folder.  So if you use this approach to reset back to the default Civil 3d palettes, you get both.  We work around that by having a folder with just Imperial palates.
