TOE WALL IN CROSS SECTION
kbb9327
kbb9327
DEAR ALL,
I WANT TO SHOW TOE WALL IN CASE-II, WHERE MY RIGHT OF WAY (ROW) IS COMING IN BETWEEN THE EARTHWORK. I WANT TO RESTRICT WITHIN ROW.
IN CASE-I WHERE I HAVE SUFFICIENT ROW, BUT IN CROSS SECTION I WANT TO SHOW BLUE LINE I.E. RIGHT OF WAY IN CROSS SECTION.
I HAVE ATTACHED BOTH PLAN & CROSS SECTION FOR BOTH CASES.
HELP.
Wojtek_Garczewski
Hi @kbb9327
Thanks for posting. As I understood, whenever ROW is encroaching your Earthworks you want to add Retaining Wall subassembly, is this correct?
Have you tried to create an assembly with conditional subassembly?
You can set up polylines targets that whenever case II is present it will find the target polyline and create a retaining wall, otherwise, it will be a daylight.
Please see:
Also, might be helpful:
Please let me know if that helps.
Wojtek
Wojtek G.
Product Owner for Civil 3D
Civil Engineering Solutions
kbb9327
Hello
Thank you for reply.
As you can see, i created conditional assembly and i give target to polyline that is ROW, but in cross section what i am looking is not what i wanted.
so what wrong i did?
Wojtek_Garczewski
Hi @kbb9327
Thanks for coming back.
If you want to have an additional slope before your RW, please try to use this configuration:
After Target Found Conditional Subassembly, add Conditional Cut and Fill, then Link Offset and Slope Subassembly with proper slope value and RW subassembly.
Also, please find the sample file attached for references.
Let me know if it works for you.
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
kbb9327
Thank you.
Here i am attaching same file with same polyline for whole length.
what i want to say is
Example. if i have stretch of 15 km then
from km 0- km 5 RE wall
Km 5- km 10 Daylight
Km 10-km 15 RE wall
Wojtek_Garczewski
Hi @kbb9327
In that case, you may have to split polyline into 3 segments, where daylights do not encroach ROW and where it does. Then target polylines in a location where you like to have your Retaining Walls. Otherwise, it will create simple daylight to the surface. Please see:
File for references attached.
Wojtek
Wojtek G.
kbb9327
Thank you @Wojtek_Garczewski for helping.
Got what i want.
