Civil 3D Forum
System Variables
10 REPLIES 10
Message 1 of 11
839 Views, 10 Replies
System Variables
As autocad now has +500 system variables. ??????
REALLY
a good ideal would be to list all of the system variables in the help file
and give examples of what they do - so users can be more productive.
as i have looked for the variable ATTIPE in the 2014 civil 3d help and it is not there . . . .
why?
why have something and not document it?
and yes, i really do want an answer from an organic life form that is an employee with Autocad.
thanks,
Charles A. Hall, eit / designer
cad user since 1993.
10 REPLIES 10
Message 2 of 11
rkmcswain
There were almost 1000 system variables a few years ago, so it's probably around that number now, certainly a lot more than 500.
The ATTIPE command is in the C3D 2014 documentation, right here.
All most of the sysvars are documented here also.
Message 3 of 11
Thank you, rkmcswain
And why is ATTIPE not in shown with the attribute text help listing?
That is the problem.
The system variables are there, someplace.
How is a user to know what system variable might be helpful to help solve a problem,
if the variable does not show up in the subject searches?
Just read the +1000 system variables?
HELP is to be helpful not a black box.
Yes, documentation of everything would be just as insane and no documentation.
Always a work in progress, toward improvement.
Cahall
Nonbeard13
Message 4 of 11
rkmcswain
Help is terrible.
Nothing we can do about it.
End of story.
Message 5 of 11
doni49
Type in SYSVDLG.  It will bring up a list of EVERY system variable and a relatively decent explanation of what they do.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 6 of 11
peterfunkautodesk
Changing this to "Solution Provided" because ATTIPE is in the help system, and SYSVDLG is a nice way to see all the system variables listed with help about what they do. That seemed to be the two main issues here.
The other implied comment from the thread is that there are too many system variables in AutoCAD. I agree there are lots of system variables in AutoCAD.
Peter Funk
Sr Product Manager
Organic Life Form
Civil 3D
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 7 of 11
Mr. Funk
Yes, there are a lot of system variables, that is to be expected with such a complex program.
The problem is: Where do you find ATTIPE if you search help for attribute text?
In civil 3d 2014 Help, I cannot find any listing of the system variable when searching attribute text.
If I enter multi-line attribute text I get MText solutions and it never gets to the attribute part.
Therefore, if and only if I know to look at the system variables will I maybe find ATTIPE.
How many users will go looking for an answer there? (very few)
So, the Help is a dead end for what should be have been documented there.
YES, the system variables are documented, but not cross referenced with the commands in the general Help listing.
Thank you for your time and response
Charles A. Hall
Designer / Engineer-in-training
PS. I have been using cad since AEC software (1993) and Civil 3D help is far superior to what once was, but there is room for more improvement.
Cah (nonbeard13)
Message 8 of 11
doni49
I went to the 2014 help, clicked search and typed in attipe.  The first listing was the ATTIPE system variable.
Don Ireland
Message 9 of 11
thank you for stating the ovious,
now, find ATTIPE under ATTRIBUTE TEXT
as that is where the normal cad user would be searching.
and if you find a reference to ATTIPE there i would lilke to see a screen shot.
thank you.
the original question was "how to create an attribute text with multiple lines of text?"
so, the normal cad user would search what?
attribute text and multiline text - agreed?
now with those two search items find ATTIPE mentioned.
my problem is - ATTIPE is not documented in the attribute text help. Why?
because it is a SYSTEM VARIABLE.
and system variables are listed seperately.
Message 10 of 11
don.ireland
Your last comment added more detail.  The first message said nothing of needing this in the ATTRIBUTE text -- just that you had looked in the C3D Help.  And that's what I based my comments on.
Message 11 of 11
Jeff_M
Charles, I don't have C3D2014 but in 2016 I searched for "multiline attribute" and got this:
That being said, I do agree that the documentation could use a LOT of work. One of the biggest things that would be of immediate benfit is making sure that all Sysvars which affect a command or object should be noted as such within each command's or object's help section.
Rail Community
