I am using Civil 3d 2017 and am trying to combine two surfaces but when I merge I don't get what I am looking for.
The below image is when I select the 2 surfaces individually and look at them in object viewer and this is what I am trying to create as a single surface:
Next is an image of what I am currently getting when combining these surfaces:
If anyone has any idea of how I could achieve a merged surface such as the first image I would greatly appreciate it.
Thanks.
Solved by Jowennl. Go to Solution.
Solved by wlewis. Go to Solution.
@MMcCall402 wrote:How are you merging the surface? Making a new surface and then pasting in the other two in the correct order?
Yes, I'm merging it by pasting them within a new created surface.
It appears as though you are creating a new surface, pasting the 'stepped' surface in first, then the sloped (red in your picture). Try creating a new surface pasting the sloped surface first, then the stepped surface.
The pasting of a surface over-writes whatever it is on top or bottom of.
@wlewis wrote:It appears as though you are creating a new surface, pasting the 'stepped' surface in first, then the sloped (red in your picture). Try creating a new surface pasting the sloped surface first, then the stepped surface.
I've tried this solution but it ends with the sloped surface being completely omitted and only the stepped one being present.
I am new to the software so perhaps there is another I do not know of to achieve the first image as a single surface?
I would edit the 'stepped' surface to limit the breaklines to where you want them to start sloping, one can also paste the stepped surface into a new surface and edit that if so desired.
Hi @Jase28x,
I replied to this yesterday but my post is not displaying. I am re-posting this <screencast> again as a guide.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
@Jowennl wrote:Hi @Jase28x,
Cheers,
Jowenn
Wow, thank you so much, this is an even better method from the way I did it before. Perfect!
