I have a drawing with an exsting ground surface and a finished ground surface. The finished ground surface will display, but the existing no longer does. I've checked layers, style and visiblity of styles and multiple styles.
the definition information all appears to be there, but no contours or triangles will display. Originally I could see them, but not anymore.
any ideas of what may cause this?
I've rebooted both my computer and the drawing, and also triec to rebuild the surface(in a temporary drawing file.
I searched the forums before posting and found no solutions.
thank you in advance
Solved by user181. Go to Solution.
Do you have a broken data reference, screen shots of prospector would help.
Rick Jackson
Survey CAD Technician VI
Did you check the style maybe everything is off, or the layer is frozen.
Rick Jackson
Your surface is on layer SV-CTRL-EXST-TXT and that layer is turned off. Turn it on to see it. Maybe you accidentally put it on that layer.
