Surface mask problem
nikoue
nikoue
Hey everyone.
I created an existing Ground surface.
For visualization purposes i use several surface masks, 12 exactly, to apply different materials to it.
10 of these masks works as expected. But 2 of them, if applied the surface, dissapear the surface in that area.
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
tcorey
Do all twelve Masks have Render Only set to Yes? Look in Mask Properties. You will need to go down your list of masks one at a time and check this setting.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
nikoue
Yes all masks have Render only mode to yes.
I solve the problem.
I recreate the polylines and the problem solved.
I don't know what problems they had.
A lot of times recreating polylines from scratch solves a lot of problems .
Thank you anyway.
