Hi @qchenTPPXV, it sounds like when the surface was deleted the left over surface profile/section was switched to "static" instead of "dynamic" update. You should be able to access all of the surfaces sampled for those sections through the Prospector:
In the Prospector expand Alignments > Alignment name > Sample Line Groups > Sections > Surface Name
Select the desired surface > right-click > Delete.
