Could someone please share a working Select Materials style sheet? This one in 2023 is only returning an Earthwork style..
Solved by lim.wendy. Go to Solution.
Hi @fcernst, I hope you're doing fine. I experienced the same issue some months ago and posted about the issue, but I haven't still found the solution for that. For the time being, I'm getting my reports with the 2020 version of the software. However, finding a solution for the 2023 version will be good.
I tried to replace the 2023 version of the *.xsl file, but it didn't work. After I did that, the report didn't appear anymore, nor did the earthwork or the select material.
Kind regards!
Thanks for replying.. this has been very frustrating..
No joy in 2020 either..
Back to 2023 the screenshot of the XML below says at the top.. there is no Style information with the file..
That's too bad!
Hi @lim.wendy, I wonder if there is any chance someone can help us with this issue?
Any help from Autodesk is appreciated.
Kind regards!
I just now tried switching my HTML viewer to Microsoft Edge from Chrome and that didn't help either.
Their XML viewer is saying it doesn't have a Style either..
Hi Fred,
Thanks for reporting this!
And thanks for letting me know Camilo. I am checking with the relevant team and will report back.
That installed Style file has a created date of 2010.. from Autodesk..
So maybe a modern Browser/XML coding issue..?
Hi guys!
Thanks for your help @lim.wendy. Getting my volume reports directly from the 2023 version will be good.
Kind regards!
Update:
Tested on 2023 version, not getting any Volume report. The XLS files seemed to only work for 2021-2022 versions.
We are checking with the engineer if we can also get an updated version for 2023.
Will circle back once I hear back.
Hi guys!
Just to let you know that I also tested the updated files, but they didn't work. Thanks again for your help @lim.wendy.
Regards!
The development team is aware of this issue and is continuing to work on fixes for these issues, and hope to deploy them in coming updates.
Meanwhile, use the 2022 version to get the volume report.
Thank you for your understanding and patience while we work on solutions! We’ll let you know as soon as we have an update!!
Hi Camilo, Fred,
I tested this on a new machine and replaced the Quantities Report Style Sheets (C:\ProgramData\Autodesk\C3D 2023\enu\Data\Quantities Report Style Sheets) folder with the files from here.
It's working. I am attaching the Mass Haul - Multiple Materials and Select Material stylesheet to this post.
Do make a backup all the xls files first.
Hi @lim.wendy, good news!
I downloaded the files you shared by the link to an Autodesk webpage, but unfortunately, they didn't work. However, I later downloaded the *.zip file that you attached to the post and replaced the files in the indicated directory and now it's working properly.
Thanks a lot!!! this issue was a pain in the neck. Yesterday I even updated to the 2023.2 version with the hope this would solve the issue, but it didn't.
I hope @fcernst can find a solution with these files too.
Kind regards!
Thanks everyone that contributed to finding a solution to this issue; I only had to spend an hour pulling my hair out 😉
Can we get a post here with the version this gets fixed in?
Hi @Coffee_Aided_Design, as I remember this post was related to C3D 2023. No matter the update you have.
Regards!
Saludos, talvez alguna solucion para la version 2022, tengo el mismo problema pero en esa version
