Surface Feature Lines disappear????
- Mute
- Permalink
- Report
This is the second time this has happened to me now. After HOURS (10) of building my surface with feature lines, I go to close C3D, then re-open my source drawing and ALL of my feature lines have been turned into zero length features, with zero elevation, at 0,0 coordinates. The last time it happened was on a 13 acre church, which had a lot of fall across the site, and 3 ponds, and to recreate that surface from scratch was a pain in the ****. Now I am working on a 20 acre apartment complex, and to all of the sudden LOSE ALL of my feature lines with no warning is extremely infuriating. I have tried loading the .bak file which comes in with the same issue: no feature lines. I have automatic save set up, but i manually save my files frequently enough that the autosave file is either not created or deletes. I have tried restoring previous versions with no success. I have tried exporting to LandXML and re-importing. The import brings in the surface and 3d polylines, but the 3d polylines are still at 0,0, 0 elevation, and 0 length. I have a hard time believing I am the only one with this issue, but I don't see anyway to get my feature lines back. If you have had this problem and know how to get my lines back, please, please let me know.
Autodesk - You need to fix this error, as this forces our businesses to lose TIME, and MONEY re-doing all of our *$%!@* work. If you won't fix the problem, then slash the price on the software so we can recoup the money we lose! I have searched the forums and the internet and it seems this has been an issue for several years now (since 2010 as far as i can tell). I have only started having this problem since I switched to 2016, but this should NOT be a bug in your software after so many years of it. This is not just an annoying nuisance, it is a major flaw with your program.
Fix it.
