Surface Elevations Table
F.Camargo
Advisor Advisor
Message 1 of 8
F.Camargo
Hi guys,
How are you?
I'm trying to insert a dinamic text to Cut and Fill into my Table.
Does anybody could help me, please?
Thank in advance
Fabrício
Replies (7)
Message 2 of 8
AllenJessup
Is this what you're looking for? ADDTOTALVOLUMETABLE
Allen Jessup
CAD Manager - Designer
Message 3 of 8
Jeff_M
@F.Camargo , Create the Volume Surface, create an Elevation Analysis with 2 ranges (1 below 0, 1 above 0) and assign the desired colors,
 create a elevation table style that has the columns and assign the Volume range and range colors:
Finally, add the Surface Elevation Table and assign it to use the Volume style. And the result:
Message 4 of 8
F.Camargo
@Jeff_M
Thank you for replay.
I’d like to insert a new column for the text “Cut” and “Fill”, just like the color. Is it possible?
thanks
Fabricio
Message 5 of 8
Jeff_M
@F.Camargo not labeled automatically. This is why I have the CUT/FILL header, meaning Cut over Fill. You could add an extra column then add the Cut and Fill text manually after the table is created.
Message 6 of 8
F.Camargo
@Jeff_M
How Can I add Cut and Fill text manually into the table?
Fabrício
Message 7 of 8
Jeff_M
You add the text using Mtext of Dtext. It is not a part of the table, just text located within the empty table column you created.
Message 8 of 8
F.Camargo
Thank you @Jeff_M
Fabrício
