I have contours in my drawing with elevations assigned. I create the surface using the existing contours and the resulting elevations are not correct. The elevations should be in the 540' range but are only around 45'. I have not had this problem before. It looks like the elevations are off almost exactly 500'.
Solved by Jeff_M. Go to Solution.
