Civil 3D Forum
Surface elevations are not correct
2 REPLIES 2
mcossins
153 Views, 2 Replies
I have contours in my drawing with elevations assigned. I create the surface using the existing contours and the resulting elevations are not correct. The elevations should be in the 540' range but are only around 45'. I have not had this problem before. It looks like the elevations are off almost exactly 500'.
Labels (1)
2 REPLIES 2
MMcCall402
in reply to: mcossins
Hmmm, check the surface edits for an entry that raises (or lowers) the surface that's built from the contours.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Jeff_M
Sounds to like a feet vs inch issue: 540/45=12
Rail Community
