Surface creation using point Grid
Gauravvpandey
Gauravvpandey
I have survey of point grid of 2x2 which makes millions of point. Converting it into COGO is a big task .Earlier i use to have export LANDXML from surface and import it into design alignment and use the surface. Please suggest me someway to make design file light and tackle this situation.
Pointdump
Hi Gaurav,
You can add a point file directly to your surface without creating COGO Points.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Gauravvpandey
Hey Dave !!! Thanks for replying , to import point directly in civil 3d needs to have details in CSV/txt format for By coordinate and elevation but i got a survey with millions of points to extract points in csv would be a long time taking task
Pointdump
Gaurav,
OK, option #2 would be to use ReCap to create an RCP file(point cloud) for import into Civil 3D. That would allow control over the number of points and level of detail in your surface.
Dave
Dave Stoll
Las Vegas, Nevada
neilyj666
As @Pointdump said unless you need to have I would never create cogo points to add to a surface as this will slow Civil 3D right down (and possibly crash it)
Can you share an example of the data you have - i assume it is a grid format in which case you could try creating a Surface from DEM OR create a standard surface and add the DEM?
You may also need to run Surface Simplification on the surface (remove 85% of the points) to reduce the size of the triangulation and avoid the creation of the dreaded mms file.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Joe-Bouza
Dataclip the area you need?
Joe Bouza
