Surface Border Exaggerate Elevation Bug
jim.poole
jim.poole
When modifying surface styles, I sometimes want to see my borders with the same vertical exaggeration as say my triangles and / or contours.
I can successfully exaggerate most surface features, but when applying the same to borders, I get crazy errors, with the border appearing to tend to +/- infinity.
Has anyone else seen this issue?
ecfernandez
Hi @jim.poole, yes! When working with very flat surfaces I usually exagerate 20 times their elevations. However, I always have to use a surface style with the border's layer turned off. I have never needed the exagerated edge of the surface and therefore never thought this was a problem. However, now that you mention it, it might be a good idea for Autodesk to work on. So, I encourage you to post that suggestion in the ideas forums.
Regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
