Hello
So I Created sub-assembly in Subassembly composer and I want to use super elevation in civil but when I imported it does not work in civil it is always the same slope on pavements I turned on SupportAOR and Axis Rotation but does not work. what shell be the problem??
here is the sample down
just when you download change .zip extension into .pkt
thank you
Solved by M_Obradovic. Go to Solution.
hi Beka_Tchighladze,
Please see Attached image and PKT file.
If you want to use Superelevation you have to change Parameter "UseSuperElev" to Yes and Also to change Lane1SuperElev parameter.
Chears Milos
this option isnot shown in my properties you send same .pkt file what I uploaded so there is nothing changed. and one thing I use all superelevation feature and I assign also it to my links in composer and why it is not enough? in civil i apply all properties also and count superelevation on alignment but it doesnot follows it always 2.5 slope doesnot change.
why does it need variables and why it does not work without it.
I read somewhere that if supportAOR funcion somethimes make a problem and I newer use it. I always use variable and newer had a problem.
It is my own oppinion.
