Has there been any improvements to rearranging subassemblies since the 2018 version?
See this link for the example problem and workaround.
https://envisioncad.com/autocad-civil-3d-tip-mark-point-subassembly-and-assembly-construction-order/
Thanks.
Solved by ilia.borisov. Go to Solution.
Thanks, this is good to know. Adding a twist, do you know how to reorder with offset assemblies?
I'm using median raised crown but it won't find the marked point because the marked point is on the offset and it looks like offsets will always be below the main assemblies subs....
