Civil 3D Forum
subassembly order
2 REPLIES 2
lambertb
283 Views, 2 Replies
subassembly order
Has there been any improvements to rearranging subassemblies since the 2018 version?
See this link for the example problem and workaround.
https://envisioncad.com/autocad-civil-3d-tip-mark-point-subassembly-and-assembly-construction-order/
Thanks.
C3D 2022 and 2024
2 REPLIES 2
ilia.borisov
in reply to: lambertb
There is no such thing as improvements in that area 😄
randyspear6624
Thanks, this is good to know. Adding a twist, do you know how to reorder with offset assemblies?
I'm using median raised crown but it won't find the marked point because the marked point is on the offset and it looks like offsets will always be below the main assemblies subs....
Rail Community
