Subassembly Issue
Subassembly Issue
F.Camargo
Advisor Advisor
Message 1 of 9
Subassembly Issue
F.Camargo
Hi friends!
I have a problem to create a corridor intersection...
I create a alignment from the curb and using this subassembly.
Is the a gap to my FG and Corridor Surface.
Is there anything wrong with my assembly?
Thank in advance
Fabricio
Replies (8)
Message 2 of 9
jameshitt
It could be the profile of your curb-return alignment, or it could be the corridor surface building to a different datum (it could be building from links below top of grade). Personally, I stopped using links to build corridor surfaces and almost always define the surface using the feature line codes.
Is the dark blue line in the second image you posted the proposed grade profile of the curb-return?
Message 3 of 9
F.Camargo
Hi @jameshitt
"Is the dark blue line in the second image you posted the proposed grade profile of the curb-return?"
Yes.
It is very confused for me, I don't know other way to do that. I've already create many alignment on my project, all the same problem.
Message 4 of 9
jameshitt
Its hard to say. I'm betting its the corridor surface definition, but I can only guess without a CAD file to examine.
Can you upload the CAD file, or some version of it?
Message 5 of 9
F.Camargo
@jameshitt
This a dwg example of my task.
https://we.tl/t-SmyIzXK0Ux
Thank in advance
Fabrício
Message 6 of 9
Matheus-Lima
Hi @F.Camargo!
Here's a proposed solution for it:
1) Create offset alignments from the alignments in the intersection. Remember to define the offset and the cross slope according to your project.
2) Use superimpose profile tool to display the profile from the offsets to your curb return profile view.
3) Modify your curb return profile using the offsets profiles as a guide. Here's a preliminary result:
Hope it helps!
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Message 7 of 9
RonaldBrañez
Hi @F.Camargo
The design profile has been created based on the bottom surface.
You can see the return curve assembly its anchor point is the top of the Lane.
Adds the top surface to the profile view and modifies the design profile, referring to the top surface.
Regards.
Message 8 of 9
jameshitt
What I can't figure out is that it does appear to me that your design profile for the curb return is correct and connects with the edge of travel way profiles (base on a surface profile of the main road). I am at a loss as to why the corridor jumps down right around the tangent points at the curb return (as seen in the surface profile).
Message 9 of 9
F.Camargo
@RonaldBrañez
Awesome friend!!
that's exactly what was happening. Thanks!
Thanks all of you guys!
Fabrício
