Subassembly Composer-Targetting to surface
Hi, I have a customized Railway subassembly created with subassembly composer... I need to create a surface target where the last lower layer is targetting the Existing surface.. in other words the Datum should be the same of Existing...
Attached is pkt file and snap showing the required section
Appreciate your kind support
Sorry I forgot to mention that... the targetting shall be subjected to a condition (If the layer top level> Existing ...then execute the target otherwise do not Apply the target )
