I'm trying to figure out how to use data shortcuts. I'm confused by the two options that appear when you right click Data Shortcuts in the Prospector tab: "Set Data Shortcuts Project Folder" and "Set Working Folder". I'm following a video (https://www.autodesk.com/certification/learn/course/course-v1:autodesk+civil3d-alignments-profiles-r...) in which the instructor in the video and the pdf instructions at the bottom of the page say to do different things. In addition, when the instructor clicks on "Set Data Shortcuts Project Folder," they're dialog box is already populated with a bunch of folders, but mine comes up blank and doesn't let me select anything. I end up creating a folder, but then it says that the folder doesn't have any data in it, which it doesn't since I just made it. The video and instructions make this seem so easy but I must be doing something wrong somewhere and I can't figure it out. Does anyone know what's going on?
