Subassembly composer help
vas.milivoj
Message 1 of 8
vas.milivoj
I have created subassembly. It makes retaining wall if certain depth, if less, it should made simple cut to surface. But it is not working. If someone is willing to check, i will appreciate
https://wetransfer.com/downloads/9381bb9eb99f65de9d88582e7dff05c120231231131651/3bba61
Replies (7)
Message 2 of 8
ecfernandez
Hi @vas.milivoj, I opened your file and moved the terrain up and down. I could see your PKT is creating both the cut and the retaining wall. Could you please tell us what is the problem you see with this geometry?
Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
Message 3 of 8
vas.milivoj
Well finaly, what is wrong is version of composer. I have created it in composer 2021, but when i use it on PC with civil 2020, ti does not work.  you can see the error message attached. it says that distancetosurface is not a member of string. so i now have to find a way to change a code, since it does not get this expression. Do you maybe know what could be the problem, or how to solve this?
Message 4 of 8
ecfernandez
Hi @vas.milivoj, try opening your PKT with subassembly composer 2020. Go to save as and make a copy of it.
Give it a try
Regards!
Camilo Fernández
LinkedIn
Message 5 of 8
vas.milivoj
see.. Any idea what to do?
Message 6 of 8
ecfernandez
If that did not work, I would replicate the flowchart in Subassembly Composer 2020. That should not hurt since your logic branches are not pretty long.
Regards!
Camilo Fernández
LinkedIn
Message 7 of 8
vas.milivoj
You will laugh 🙂
i made point codes and link codes variables of the same name as points and links
For point P1 i made p1, P2 , p2, L1 l1.... that confused it 🙂
thank you for your help 🙂
Happy NY 🙂
Message 8 of 8
ecfernandez
Hi
It's good to know you figured it out.
I'm always happy to help.
Happy New Year!
Camilo Fernández
LinkedIn
