I have a manhole that is offset from the alignment, when it was drawn into the profile view it place the MH at the correct station on the alignment put in the profile view it is not in the correct spot. The offset is 20' L of the alignment. How do I get it in the correct spot in the profile view?
Stephen Foster
Hi
"the correct spot " you mean the location at the profile (station) or the top level of the manhole to match the profile line .
because you already mentioned that "it was drawn into the profile view it place the MH at the correct station"
you can view it " draw part in profile view "and add label "single part profile" in it. the manhole will be shown in the road profile.
