Storm and Sanitary Analysis will not Import Catchment
info6RUDZ
Message 1 of 11
info6RUDZ
I asked a similar question before on this forum, and didn't really get a solution. I am analyzing a natural terrain, and created two Catchments connected to structures. One catchment was imported into SSA as a subbasin but the other did not. There is virtually no difference between the two catchments and i just can't understand why SSA would leave the other one out. Attached is a C3D file with catchments DMA 2 and DMA 3. DMA 2 was imported successfully but DMA 3 was not. Anybody got any ideas? Thanks in advance.
Replies (10)
Message 2 of 11
matt_anderson_pe
For SSA to recognize a catchment, it needs all of the elements needed to compute runoff.
  1. The polygon (by definition - the object)
  2. Runoff Coefficient (by default)
  3. Time of Concentration (to be calculated or established)
If one is missing, SSA does not import it.  It probably should - but a zero time of concentration (as DMA3 has) would not result in calculated flow.   Now - you have a flow path - but that flow path has a negative slope, and the TR-55 calculation can't handle that, resulting in 0 for your Tc.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
Message 3 of 11
Joe-Bouza
Pardon if this is ignorant. Isn't that catchment, curve#, TC and discharge point?
Joe Bouza
Message 4 of 11
matt_anderson_pe
Yes @Joe-Bouza  you are correct.  Discharge is the element I missed.
The catchment object requires:
  1. Runoff Coefficient
  2. Tc > 0
  3. Discharge Point
and you get a catchment outline.
Inundar, LLC
Message 5 of 11
info6RUDZ
That worked. Thanks a lot, @matt_anderson_pe and @Joe-Bouza
Message 6 of 11
fcernst
Are you getting the Catchment boundary vertices importing?
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 7 of 11
info6RUDZ
@fcernst no, since i only imported the pipe networks into SSA, the catchment was imported as a background. It would be great to know if there is a way to be able to directly import the catchment into SSA without having to go through intermediate processes.
Message 8 of 11
matt_anderson_pe
Catchment boundaries will only be imported from LandXML parcels - a quirk of SSA from the BOSS days...  They dont add anything to the model beyond the graphic representation of Area.
Inundar, LLC
Message 9 of 11
fcernst
You can import and create subcatchments from GIS polygons and map the fields.. but we need SSA to bring in the Catchment vertices in one efficient operation all linked up and ready to go... for sharing SWMM *.inp files to other watershed study team members who expect the vertices to be in the SWMM *.inp file..
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 10 of 11
matt_anderson_pe
@fcernst-
True - but just like Parcels - it's a multi-step process from a Catchment object.
Inundar, LLC
Message 11 of 11
fcernst
Yes.. that’s what I’m saying..
Fred Ernst, PE
C3D 2027
Ernst Engineering
