Message 1 of 19
Hi. how can solve connect the daylight to the last target surface in the subassembly composer?
Actually, 38.30 is the elevation target but I want to connect daylight to last surface
That’s just typical slope/elevation target scenario..then typical daylight scenario.. after the road/whatever ..not a multi-intercept daylight scenario.
For a multi scenario at 4:1 send an auxiliary link out at 4:1 for a distance well past all the possible surface intersections.. then daylight back to pick up the last daylight intersection point
I didn't understand, what do you mean!?
The 4:1 was just an arbitrary slope….example
You don’t have a daylight multi-intercept scenario here…….
I shredded the pkt you can check the file!
I have tried to solve it but I couldn't!
@BrianHailey but I don't know how I do it?
Create an axillary point that extends way out beyond your surface.
And then create a point daylighting back the other direction from that axillary point.
I did it, but the problem was not solved!
Unfortunately, I have not solved this problem yet!
I have been attempting but I wasn't successful could you check please check the pkt!?
Yes i will look in your subassembly.
Could you please also share the concept of this typical section?
I want to know exactly how it works.
Do you have any sketch from your typical section?
@giscivil92 change the extension of the .pkt file to .zip and then share it.
I shared it.
Since you haven't explained what exactly you want I'm going to assume that you want L102 in your subassembly to daylight to the last point that it would cross the surface target EG.
To do this, create an axillary point from P60 at the same slope that you would daylight so that it extends way beyond the limits of your surface. From that axillary point, create another axillary point that slopes to surface back along the path of the original axillary link. Now, create point P91 at that axillary point and then link L102 between point P60 and P91 and you're done.
In essence, go out beyond your surface and then daylight back, that's your last surface crossing. Now create a point there and link it to the previous point.
