Greetings Ladies and Gents,
I'm running into an issue when trying to draw a line from Station offset on an alignment, where i can no longer select a different alignment after having run the command first.
I will use the "Create Line by station/ offset" , select alignment "A", and then type in my station and offset values. like show in my first screenshot.
However when i repeat this process, it will automatically select alignment "A" as the baseline and i can no longer choose a different alignment unless i close and reopen the file.
Im running C3D 2018 on windows 10 and dont have any weird disruptive settings to the best of my knowledge.
asks me to select an alignment.Auto selects my previously used alignment as the baseline
Thanks, -Scott
